LMI drill press rosette cutter
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=5557
Author:  af_one [ Thu Mar 09, 2006 11:23 pm ]
Anyone using this cutter in their drill press from LMI?? I've considered buying one--is there an advantage using it over the foredom with the Stewmac base rosette cutter? Seems simple, just not sure of it would cut cleaner, so before spending $175, I thought I'd ask.
Author:  tippie53 [ Fri Mar 10, 2006 12:52 am ]
     used it once I don't use it no more
john hall
Author:  stan thomison [ Fri Mar 10, 2006 1:09 am ]
little tough initially to setup, but once done it is better than dremel or other tools IMH. Takes less than a minute to put top on drill and cur channel. Very clean cuts at good depth. Just need to make sure it is setup and drill is setup so quill (sp) is prepindicular to table.
Author:  Brock Poling [ Fri Mar 10, 2006 3:27 am ]
I think if you were making the same rosette over and over and over it would be great.
I have looked at it before too.
Author:  peterm [ Fri Mar 10, 2006 3:36 am ]
I like the results and the time it takes to cut a rosette....great for repetitive same exact size rosettes because is a major pain to setup! It cuts clean and fast but it will takes a few frustrating attempts to set it up right!
If you decide to get one make sure to try first on scrap wood!
Author:  John Mayes [ Fri Mar 10, 2006 3:45 am ]
I have one and I have never used anything better. It's as good or better
than any other jig out there for repeating a standard rosette.
Author:  Pwoolson [ Fri Mar 10, 2006 4:16 am ]
One thing I might suggest is installing some x-acto blades on the inside and outside of the rosette cut. It will offer a much cleaner cut than the chisels that scoop out the wood.
Author:  Brad Goodman [ Fri Mar 10, 2006 4:54 am ]
I have this tool, and I like it.
Author:  crowduck [ Fri Mar 10, 2006 6:59 am ]
Martin Guitar sells a drill press soundhole & rosette cutter for $18.95.
CrowDuck
Author:  RussellR [ Fri Mar 10, 2006 7:00 am ]
I think you have about got it Hesh
I looked at this tool, but I tend to do a lot of different rosettes so decided it wasn't for me, if you use a three ring rosette with standardised ring dimensions then I reckon it would be ideal.
There is a version by luthier tools that looks easier to adjust but from memory it is around $300
Author:  L. Presnall [ Fri Mar 10, 2006 10:26 am ]
I'm with John Mayes...(well, not right now, right now I'm at home... )...but I have the LMI and love it, and even changing the configuration to a different rosette style (not too often) the guaranteed result I get from the tool is worth the time re-configuring...Crowduck, I'm intrigued...what tool is Martin selling? Sounds like maybe it's a hardware store type flycutter? For the $$ I can't see anything more substantial and the LMI is nothing if not substantial! Just my humble opine...
Author:  James Orr [ Fri Mar 10, 2006 10:58 am ]
I had it and wasn't able to use it. It didn't come with cutters, and I didn't
realize that.
Author:  crowduck [ Fri Mar 10, 2006 11:16 am ]
Yes, the Martin tool is a flycutter. Don't know if it's 'hardware store' quality. I used a flycutter in a luthier school I attended for cutting rosette channels, and soundhole. I was impressed by its ease of use, and the quality of the cuts. Results may vary with brand/quality of the flycutter of course, and the drill press.
CrowDuck
Author:  Brock Poling [ Fri Mar 10, 2006 2:11 pm ]
[QUOTE=James Orr] I had it and wasn't able to use it. It didn't come with cutters, and I didn't
realize that. [/QUOTE]
What did you do with it.
Author:  James Orr [ Fri Mar 10, 2006 8:07 pm ]
John Greven made me some cutters, but they ended up not fitting. I'm
pretty sure I sold it. I know I don't have it now.
Author:  L. Presnall [ Sat Mar 11, 2006 4:03 am ]
The LMI didn't come with cutters? Mine did! I wonder if that was a mistake in the s/h dept?
